DIAdem
How to compare 48 channels to find outliers
I want to compare 48 channels of voltages, each channel should be similar in value normally. However some are dropping in voltage which indicates a problem in our system, so I would like to be able to easily identify those cases. Is there a way to look at all 48 channels row by row and pick out which channels vary the most compared to the others? I'd like to have a script for this and then report the results onto my report. They will range from zero to 1.1 volts and if a channels varies from the others by more than 0.1, I would like to easily identify which channel this is.
Thanks in advance for any help!!!
(1,069 Views)
Hi Karen,
Lots of ways to do this.  Below is one way.
Dim oGrp, oChn, iRow
'Create some data..
Call Data.Root.Clear
Set oGrp = Data.Root.ChannelGroups.Add("VoltageOutliers")
Set oChn = oGrp.Channels.Add("V1_NoOutliers",DataTypeChnFloat64)
For iRow = 1 To 10
  oChn.Values(iRow) = Random(1.1)
'Create a 2nd channel 'V2_Outliers' with values randomly 0.1 greater than channel 'V2_Outliers'
Set oChn = oGrp.Channels.Add("V2_Outliers",DataTypeChnFloat64)
Call Calculate("R = A + Random(0.16)",array("R","A"),array(oChn, Data.GetChannel("VoltageOutliers/V1_NoOutliers")))
'Make sure at least one row is > 0.1 by assigning a direct value to row 5
oChn.Values(5) = Data.GetChannel("VoltageOutliers/V1_NoOutliers").Values(5) + 0.1
'Create a new channel 'Subtracted' with the difference between channels 'V2_Outliers' and 'V2_Outliers'
Call ChnSub(Data.GetChannel("VoltageOutliers/V1_NoOutliers"), oChn, "/Subtracted")
''Filter channel 'Subtracted' by 0.1 and create new channel 'LimitByThreshold'
Set oChn = oGrp.Channels.Add("LimitByThreshold",DataTypeChnFloat64)
Call Calculate("R = IIF(ABS(B)<0.1,NoValue,ABS(B))",array("R","B"),array(oChn,Data.GetChannel("VoltageOutliers/Subtracted")))
(990 Views)
