DIAdem
How to create a new channel in the data portal of type String/Text?
I was looking for a way to store the names of the channels coming from my database --> to the channel, but its not working.
I tried something like this:
set oChnXname = data.Root.ChannelGroups("Exp Channel group").Channels.Add("ChnXname",Datatypestring)
oChnXname(i)=(RS.fields("xchannel"))
Any help is highly appreciated
Thanks in Advance.
(3,454 Views)
You create a new channel oChnXname.  What is the value of "i"?  If it is 0 that won't work.  Also, nee to use oChnXname.Values(i).  Also, no idea what RS object is.
(3,438 Views)
'i' is:
i=1 to rowcount(RS) ' RS is the record set obj for the data coming from DB
(3,421 Views)
Possible reasons why doesn't work:
1. You use channel(i) instead of channel.Values(i)
2. (RS.fields("xchannel")) is not returning you a String type.  Try converting it to String.
3. (RS.fields("xchannel")) is empty
It is hard to know what the exact issue is since you haven't showed an error message or wrong output of your existing script
(3,416 Views)
I tried:
oChnLimit.Values(i)=(RS.fields("limit"))
1. tried
2. data in the database is of varchar type, so i used data type string while creating channel
set oChnLimit = data.Root.ChannelGroups("Exp Channel group").Channels.Add("ChnLimit",Datatypestring)
3. no, its not empty
(3,408 Views)
Accepted by topic author Kandukuri_raghavendra
yes so the error message says that you are trying to put a vbObject into the string channel you created.  You must have some sort of loop to assign each value from RS (table?) to a value in your new channel
Like:
If not RS.EOF Then
  RS.MoveFirst
  Do While not RS.EOF
    Call LogFileWrite(RS.Fields("limit"))
    RS.MoveNext
  Loop
End If
Will that log strings?  or do you need to do something like RS.GetString?
(3,401 Views)
Not sure if i need to log strings , but i tried to assign it to a temporary variable and then assigned that to obj, channel is referring to and it worked out.
   Dim tempA
            tempA=RS.fields("xchannel")
            oChnXname(i)=tempA
(3,388 Views)
