DIAdem
How to create a zip file
I would like to ask how to pack exported data from DIAdem to zip?
Thank you for advance.
Radek
(5,599 Views)
Accepted by topic author Radek_Codr
Hello Radek,
you can use the gnu tools for win32.
They contain two executables zip.exe and unzip.exe that you can ship for free and use a script like the following.
Takse some time to check the parameters of the two little tools.
Option Explicit  'Forces the explicit declaration of all the variables in a script.
dim zipFile : zipFile = CurrentScriptPath & "example.zip"
if FileExist(zipFile) then
  FileDelete zipFile
end if
call AddToZip(zipFile, CurrentScriptPath & CurrentScriptName)
dim outPath : outPath = Unzip(zipFile)
MsgBox "Extracted to: " & outPath
Sub AddToZip(filePath, fileToAdd)
  dim shell : Set shell = CreateObject("WScript.Shell")
  dim zipCmd : zipCmd = CurrentScriptPath & "\zip.exe"
  dim command : command = """" & zipCmd & """ -D -j """ & filePath & """ """ & fileToAdd & """"
  dim status : status = shell.Run(command, 0, true)
  if(0 <> status) then
    err.Raise 100, "", "zip.exe failed with status " & status & "."
  end if
End Sub
Function Unzip(filePath)
  dim tempDir : tempDir = shell.Environment("Process")("Temp") & "\myoutput"
  dim unZipCmd : unZipCmd = CurrentScriptPath & "\unzip.exe"
  dim command : command = """" & unZipCmd & """ -o """ & filePath & """ -d """ & tempDir & """"
    err.Raise 100, "", "unzip.exe failed with status " & status & "."
  end if
  Unzip = tempDir
End Function
Greetings
Andreas
(5,592 Views)
Since win XP
Sub AddToZip(zipFile, folderToZip)
  dim sa : set sa = CreateObject("Shell.Application")
  dim zipFileObj : Set zipFileObj = sa.NameSpace(zipFile)
  dim fol : Set Fol = sa.NameSpace(folderToZip)
  zipFileObj.CopyHere(Fol.Items)
End Sub
Sub Unzip(zipFile, unzipToFolder)
  dim filesInzip : set filesInzip = sa.NameSpace(zipFile).items
  sa.NameSpace(unzipToFolder).CopyHere(filesInzip)
End Sub
 seems to work too.
(5,583 Views)
Thanks for the advice, but packing using second method does not work. I think you need to first create a Zip file, including the appropriate header, and then you can write to him.
Sub Zip(sFile, sZipFile)
	Set oZipFSO = CreateObject("Scripting.FileSystemObject")
	Set oZipFile = oZipFSO.CreateTextFile(sZipFile)
	oZipFile.Write Chr(80) & Chr(75) & Chr(5) & Chr(6) & String(18, 0)
	Set oZipApp = CreateObject("Shell.Application")
	oZipApp.NameSpace(sZipFile).Copyhere sFile
End Sub
Some example can be seen on: http://www.naterice.com/articles/64
Radek
(5,515 Views)
