DIAdem
How to define the terminals of the LabVIEW Express-VI "DIAdem Report"?
Hi everyone,
I've got quite a fundamental question concerning the generation of DIAdem reports from LabVIEW:
How do I define the terminals of the Express-VI "DIAdem Report"?
Eventually, I want to display several graphs in my report. I therefore need several input terminals to the Express-VI. I already realized that the amount of signal terminals is dependant upon the TDR layout file I use. However I didn't find a way to define them in DIAdem.
Thank you in advance!
Markus
(4,751 Views)
Hi Markus,
the terminals in the VI depend on the amount of 2D-Axis-Systems you are using. Eg. when you need for axis-systems you place them in the report where you want to have them. Then you will be able to write the data for 4 graphs from LV with the VI.
I hope this helps,
RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(4,714 Views)
Thank you, RMathews! That was just what I was looking for. However, I realized the DIAdem Report function in LabVIEW doesn't offer me enough possibilities to implement the functionality I need. I therefore proceeded to do it directly in DIAdem using VBScript.
(4,671 Views)
Edit: The main problem I faced was that I'm working with an XY-graph here, which I cannot transfer to a waveform.
(4,667 Views)
