DIAdem
How to find the program DIAdem? How to delete it?
I'm a beginner in Labview, thanks for your help.
I want to use the program DIAdem to analyse my file .TDM, but I can't find the program in National Instruments, then I think I have no this soft, so I download  the evalution version from the site.
When I start the installation, a message: you have already DIAdem 10.2, you need delete the old one and then restart. After that, I checked it in control panel >> delete , but I can't find it.
At last, I checked the mail from the activation code, the program has been activated.
I don't know where the problem is,  can anyone gives me a help?
Lily
(4,584 Views)
Hello Lily!
In the 'Software' list you have to look for 'National Instruments-Software'. If you open this you get a list of installed NI software. There should be DIAdem.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,578 Views)
Hello Matthias,
Thanks for your answer, but I have no this program in my list NI.
Lily
(4,574 Views)
Hello Lily!
OK, there was a problem in the past with a part of DIAdem wich is also installed with LabView, the USI. Sorry but i can't remeber the solution.
Perhaps one of the NI guys can help?!
Matthias
Matthias Alleweldt
Twigeater?
(4,570 Views)
Hi Lily,
Send me an email so that we can attack this directly together.  DIAdem R&D sent me a set of instructions and an application for you to run, but it would be best to take this offline.
brad.turpin@ni.com
Brad Turpin
(4,525 Views)
hello,
The problem is resolved in my PC with Windows XP, I installed the evaluation version, and it can search the activation code automatically.
But with my PC VISTA, it has always the same problem.
Maybe it's  a problem with the Windows system.
Thanks for Matthias and Brad.
Lily
帖子被Lily1979在03-25-2008 06:39 PM时编辑过了
(4,518 Views)
