10-21-2009 08:07 AM
I want to read and write TDM-Files in a Java-Application.
I found the TDMHeaderWriter for Java, that can write TDM-Files, but the reading part is still missing.
Perhaps anyone knows an equivalent in Java to the TDM C DLL and the TDM C Header DLL?
Thanks Verena
10-21-2009
09:56 AM
- last edited on
04-09-2026
07:43 AM
by
Content Cleaner
Hi Verena,
the TDM Header Writer is also available for Java:
Unfortunately there is no Java equivalent for the TDM C DLL
Stefan
10-22-2009 01:18 AM
Hi Stefan,
thanks, I already tried the TDM header Writer Java API.
Unfortunatelly it is only half the battle, because I've also to read TDM files.
Verena
10-22-2009 01:31 AM
Hello Verena!
With a thin C layer it should be no problem to connect the TDM C DLL to Java via JNI. The main part could be done in a few hours but isn't a out-of-the-box solution.
Matthias
| Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
10-22-2009 01:39 AM
10-22-2009 04:09 AM
Cool ![]()
Can you please give me feedback on this project if you have finished it?
Matthias
