DIAdem
How to read out the directory of the loaded data in the Data Portal?
Hi!
I'm writing a script which asks the user where to save an auto generated Report-File. The suggested folder is always G:\TSM:
FileNameGet("REPORT", "FileWrite", "G:\TSM\" & Filename & ".TDR"
I want the dialog to suggest the folder where the loaded TDM file is stored, something like "DataFileFolder":
FileNameGet("REPORT", "FileWrite"DataFileFolder?! & Filename & ".TDR"
Is there a method to get the folder of the loaded data?
Sascha Zimmer
Message 1 of 8
(4,768 Views)
Hi Sascha,
every channel in the DIAdem data portal has a property named sourcedatafilepath.
For Example:
Dim SourcePath
SourcePath = Data.Root.ChannelGroups(1).Channels(1).Properties("sourcedatafilepath").Value
Call FileNameGet("REPORT", "FileWrite", SourcePath & Filename & ".TDR")
Hans Beckers
Message 2 of 8
(4,761 Views)
Works perfect! Thanks for your help!
Message 3 of 8
(4,749 Views)
after i implemented the code an error occures if i have no data loaded in the data portal.
It says "Index 1 is not an element of the listing" - logically if theres no channel and no group.
How can i check if any data is loaded in the portal?
Something like
If Data.Root.ChannelGroups(1).Channels(1).Exists = true then...
Regards
Sascha Zimmer
Message 4 of 8
(4,746 Views)
Hi Sascha,
you can check the number of channels in the first group:
Dim NoOfChannels
NoOfChannels = Data.Root.ChannelGroups(1).Channels.Count
if noOfChannels > 0 then
Regards
Hans Beckers
Message 5 of 8
(4,741 Views)
Hi Hans!
Thanks for your reply! Your code does the right thing if any data is loaded.I got the same error than before because the Index 1 from ChannelGroups(1) doesnt exist.
My problem is that if there is no data loaded at all, there are also no channels and no channel groups. What can I do to check if the whole Data Portal is empty or not?
Regards
Sascha Zimmer
Message 6 of 8
(4,727 Views)
Hi Sascha,
you can count the channelgroups, which are loaded to the data portal:
Dim NoOfChannelGroups
NoOfChannelGroups = data.root.channelgroups.count
If NoOfChannelGroups > 0 then
Regards
Hans Beckers
Message 7 of 8
(4,725 Views)
Accepted by topic author Sascha Zimmer
I found a solution by myself:
If Data.Root.ChannelGroups.Count > 0 then
Works fine even theres no ChannelGroup defined.
Regards
Sascha Zimmer
Message 8 of 8
(4,653 Views)
