DIAdem
How to replace units of a channel through scripts%3F
I have few queries regarding the manipulation of the channel property 'unit' by scripts.
Case 1: If the unit of the channel is not specified in the properties, what command should be used to add the unit in it?
Case 2: When I create channel using 'Call.Root.ChannelGroups(1).Channels.Add("name", DataTypeFloat64,1)', the unit space being empty, what other command can be used which has the provision for units within?
Case 3: Consider I have channel (Channel A) with unit already defined (x), How can I replace the unit with another one (y)? (Units x and y belong to different physical quantities, so the ChnUnitConvert)
Pls let me know if you nee more clarifications on the same.
Fazil Shah.
(7,944 Views)
Accepted by topic author faz_shah
Hi Fazil,
The key word for units in DIAdem SCRIPT is "unit_string". If you open SCRIPT and open the channel property list you can select the unit property and drag & drop it into the SCRIPT editor. This creates the script code for the property.
Case 1
You have tow options: a full quallified assignment or a channel object variable (if you have more settings for the channel the second variant is better)
Data.Root.ChannelGroups(1).Channels("MyChannel").Properties("unit_string").Value = "MyUnit"
or
dim oChn
set oChn = Data.Root.ChannelGroups(x).Channels("MyChannel")
oChn.Properties("unit_string").Value = "MyUnit"
case 2
You need to add the unit after creating the channel
set oChn = Data.Root.ChannelGroups(x).Channels.Add("MyChannel", DataTypeChnFloat64)
case 3
This is the same like case 1 or if you would like to use the unit of an already existing channel it can looks like this
oChnA.Properties("unit_string").Value = oChnB.Properties("unit_string").Value
I hope this answers your questions
Greetings
Walter
(7,933 Views)
Hi Walter,
It worked. Thanks a lot.
Fazil Shah.
(7,923 Views)
