DIAdem
sql query
I have a MS SQL server express database.  I got success to use the Data Store to get a table out of my the database in the NAVIGATOR screen.
What I would like to do, is to perform a query from this table and send the result of the query to the Data Portal.
Can someone help me with this?
(6,345 Views)
Have you tried running the Advise loop independently of the other?
Daniel G.
Semiconductor & Wireless
(6,323 Views)
Hi labsergio,
See if you can adapt this script to your needs.  You'll need to swap out the ADO connection string for the one that works on your data base, and you'll need to change the table and column names also.
OPTION EXPLICIT
Dim z, zMax, ADO, RecordSet, Table, ColStr, CondStr, SortStr, ConnectionStr, QueryStr, RowVals, Channels, AsPos
' needs to be set to a valid ADO connection string for ACCDB file
ConnectionStr = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" & AutoActPath
ConnectionStr = ConnectionStr & "DataMine.accdb;Persist Security Info=False"
' needs to be set to a valid ADO connection string for MDB file
ConnectionStr = "Driver={Microsoft Access Driver (*.mdb)};Dbq=" & AutoActPath
ConnectionStr = ConnectionStr & "DataMine.mdb;Uid=;Pwd=;"
' construct the SQL query to execute
Table   = "DataTableWrite"
ColStr  = "*" ' "DatID,Name,Owner"
CondStr = " WHERE DatID < 200"
SortStr = " ORDER BY Name"
QueryStr = "SELECT " & ColStr & " FROM " & Table & CondStr & SortStr
MsgBox QueryStr
' Connect to the data base
Set ADO = CreateObject("ADODB.Connection")
ADO.Open ConnectionStr
' Execute the query and import the resulting data records into a VBScript variable
Set RecordSet = ADO.Execute(QueryStr)
RowVals = RecordSet.GetRows()
' Send the resulting data records from the query to new channels in the Data Portal
Call DataDelAll
Call GroupCreate(Table)
Call GroupDefaultSet(GroupCount)
Channels = Split(ColStr, ",")
IF Trim(ColStr) = "*" THEN
  zMax = RecordSet.Fields.Count-1
  ReDim Channels(zMax)
  FOR z = 0 TO zMax
    Channels(z) = RecordSet.Fields(z).Name
  NEXT ' z
END IF
For z = 0 To UBound(Channels)
  AsPos = InStr(UCase(Channels(z)), " AS ")
  IF AsPos > 1 THEN Channels(z) = Trim(Mid(Channels(z), AsPos+1))
  Channels(z) = "[" & GroupDefaultGet & "]/" & Channels(z)
Next ' z
Channels = ArrayToChannels(RowVals, Channels, 1)
' Disconnect from the database and output the query used and any errors
ADO.Close
Brad Turpin
DIAdem Product Support Engineer
(6,281 Views)
