DIAdem
How to send text labels to Diadem from LabVIEW?
Is it possible to place text labels in a Diadem report from LabVIEW at runtime? Lets say by specifying its coordinates, text lable name and value? Thanks..
(3,758 Views)
Accepted by Yashasvi
Hi Yash,
Yes it is possible to place text labels on a report from LabVIEW at runtime using the same piece of code I linked to in your other post.
In this instance you need to modify the 2D array with a new set of commands. The commands in VBScript are listed below.
Call GraphObjNew("FreeText","Text4")
Call GraphObjOpen("Text4")
  '------------------- Text -----------------------------
  TxtTxt           = "Test"
  TxtFont          = ""
  TxtSize          = 3
  TxtColor         = "black"
  TxtColorRGB      = 33554432
  TxtBold          = 0
  TxtItal          = 0
  TxtUndl          = 0
  TxtStrOut        = 0
  TxtFrame         = 0
  TxtBackColor     = ""
  TxtBackRGB       = 50331647
  TxtBackRGB2      = 15263976
  TxtBackFMode     = "Vertical"
  TxtBackFVariant  = "From bottom"
  '------------------- Position -----------------------
  TxtPosX          = 36.47
  TxtPosY          = 15.83
  TxtAng           = 0
  TxtRelPos        = "r-bot."
Call GraphObjClose("Text4")
You will need to convert these for the VI.
The conversion you need to follow is as such: Where ever you have Call you replace that with Cmd
so Call GraphObjNew("FreeText","Text4") becomes Cmd    GraphObjNew("FreeText","Text4")
and TxtTxt           = "Test" becomes  Var     TxtTxt     "Test"
ignore any lines starting with '
so the first few lines of the script become as such in the array control.
Cmd    GraphObjOpen("Text4")
Var     TxtTxt     Test
Var     TxtSize    3
and so on.
You can also ignore lines with = "" as we need to remove the "" when we are sending Variables.
Regards
JamesC
NIUK and Ireland
It only takes a second to rate an answer 🙂
(3,730 Views)
