DIAdem
How to set elements in the Table Control center alignment
I Creat a Table Control to display one channel data in User Dialog Box.
I want the elements in the Table to center in alignment. But i dont know how to set elements in the Table Control center alignment .thanks all
(3,385 Views)
You may use Property Node of the table to change the alignment of the data being displayed.
Find the control/indicator on the block diagram, right click and select Create » Property Node » Text » Justification. Create a enum constant and select "center".
Reference Link
Jared Loy
AE National Instruments
(3,275 Views)
Thank you very much for your reply.
But I want to know how to implement it in DIAdem User Dialog Box.
I'm sorry I didn't specify what kind of software it was, but I thought it was in the DIAdem section and everybody defaulted to it.
(3,270 Views)
Sorry. I was no realized that I am in Diadem sub-forum.
To set data in table control using center alignment you may refer to these 2 links.
Alignment for Text
Alignment for Channel Table
Thank you.
(3,246 Views)
Accepted by SmallFox
Hi SmallFox,
There are 2 table controls in DIAdem SUDialogs, the older, static Table control, and the newer XTable control.  The older, static Table control is simpler to use, but it can only display column content left-aligned.  The newer XTable is a lot more flexible, since its cells display what a callback function of your designing determines should be dynamically displayed, and it supports left, centered and right justification.
Would it be an option for you to switch to the XTable instead of the older Table control?  Otherwise you're stuck with only left justification.
Brad Turpin
(3,235 Views)
Thank you for your reply. Your explanation is very good. I will switch to XTable.
Thank you ,Brad Turpin,best regards!
(3,226 Views)
