DIAdem
How to setup the same value in Digital Filter and the Crash Digital filter
Message 1 of 9
(10,894 Views)
Can you give more info here?  I assume you are asking what settings to use in the Digital filter dialog to approximate the Crash filter specs.
Your best choices are:
for CFC60  IIR, Butterworth, order 4, Force zero phase, Lowpass, Filter freq = 100 Hz
for CFC180  IIR, Butterworth, order 4, Force zero phase, Lowpass, Filter freq = 300 Hz
for CFC600  IIR, Butterworth, order 4, Force zero phase, Lowpass, Filter freq = 1000 Hz
for CFC1000  IIR, Butterworth, order 4, Force zero phase, Lowpass, Filter freq = 1650 Hz
Hope this answers your question.
Message 2 of 9
(10,873 Views)
Please have a look at page 134 of the attached PDF file, it gives some information about the CFC filter procedure.
Otmar D. Foehner
Message 3 of 9
(10,853 Views)
thanx for reply... It`s helps me....Smiley Happy
Message 4 of 9
(10,823 Views)
How is it going SArm?
Thx for those CFC values. I am not a Diadem user and am currently using a pcie 6259 daq board for collecting data from accelerometers in crash test simulations.
I was wondering how can you setup a butterworth filter for a CFC 60 IIR with a force zero phase in labview 8.5. Help would be much appreciated.
regards
don
Message 5 of 9
(10,126 Views)
Uhm, well....I am not a Labview user so I really don't know how to tell you what to do.  The CFC filters are a detailed on page 5-21 of the pdf document attached to one of the above replies.  It would be a pain to implement this, but if Labview does not allow you to force zero phase it may be your only choice.
Message 6 of 9
(10,117 Views)
Correction...it is page 6-29 on the above document.  I was looking at another version.
Message 7 of 9
(10,114 Views)
indeed it would b a pain in the...neck.
I`ll have a look at  the pdf.
thx for your help mate
cheers
don
Message 8 of 9
(10,094 Views)
Sorry to dig up an old thread, but I am trying to implement a CFC 1000 filter in LabVIEW 2009.
The Crash Safety Spec states:
3 dB limit frequency : 1650 Hz
Stop damping: -40 dB
Sampling Frequency: at least 10 khz
From this thread I got the following information:
How would I implement this? I am using a Digital IIR Filter, what would the filter parameters be?
Paul
Message 9 of 9
(8,209 Views)
