all the examples i've seen use channel names to specify the channels but i want to use the channel number so i can loop through several. I can't figure out how to do this in vbscript
I've tried:
for i = 1 to 4
Call FormulaCalc(Ch(i) = Ch(i)*2)
next
using several variations of double and singel quotes with no luck. It works if i use the channel number instead of i but I want to be able to loop through a long list of channels to do the same calculation....any help??
thanks
