DIAdem
Insert Graphic to the Report via VBS
I am trying to insert a graphic (*jpg) to the report via VBS-Script. I tried with following code:
Call GraphObjOpen("Metafile1")
  MTAFILENAME      = "C:\test.jpg"
  MtaPosX          =28
  MtaPosY          = 78.84
  MtaRelPos        = "r-bot."
  MtaWidth         = 6.86
  MtaHeight        =4
  MtaRatioAdapt    =0
  MtaBackColor     =""
  MtaBackRGB       =0
  MtaEmbedded      =0
Call GraphObjClose("Metafile1")
Call picupdate
I have 2 pages report. My problem is that the graphic appears on the second page not on the first page. doese anyone has an idea how to fix this problem?
thnx
(3,931 Views)
Hey
You will have to set the acitve sheet:
Call GRAPHSHEETSHOW("Blatt 1")
(3,926 Views)
Christian is correct, but if you use an English version of DIAdem, the correct command is:
    Call GRAPHSHEETSHOW("Sheet 1")
unless you have changed the name of your sheets. If you have custom names, add the name of the sheet you are looking to edit between the " ".
Otmar D. Foehner
(3,917 Views)
This is why copy and paste is so bad Smiley Wink
(3,910 Views)
thank you very much your quick answers.
(3,896 Views)
