DIAdem
Inability to Register GPI Index with DIAdem 10.2
I am trying to use a Spider8 from HBM with DIAdem 10.2, DAC Bundle.  My previous version of 9.1 Professional DAC Kit did not have any problems with the .dll DIAdem needed.  Now, when I try to perform the same setup to register the Spider within DIAdem, I recieve the following error on the startup of DIAdem:
Note for the GPI Extention registration
Cannot load the DLL "Addinfo\GFSSPID8.DLL".  (Error number:  The specified module could not be found)
Has something changed from 9.1 to 10.2 with regards to the registration?
Thank you for your help.
(4,368 Views)
the spider 8 driver for DIAdem depends on several DLLs provided by HBM. You can find these DLLs in the folder where you have installed the configuration program for the spider 8. Just copy all dlls from that folder to your DIAdem program folder. This should help.
Rainer
(4,343 Views)
I have the same problem, did you resolve it?
If yes, what did you do?
(3,758 Views)
