DIAdem
Is TEDs transducer information saved in the .tdms file?
I have a TEDs-capable Pressure Transducer connected to a NI-9237 module in a cDAQ-9174. In this application, I am collecting data using SignalExpress 2014. The attached file shows the information displayed in MAX, for the TEDs-capable transducer. When I collect the data, is the TEDs information saved as metadata into the .tdms file? I do not see it in the channel properties within DIAdem. Thank you.
(5,240 Views)
Hi ATarman,
You've landed in the DIAdem Discussion Forum.  This is a data acquisition question more suited to a Signal Express or LabVIEW Discussion Forum.
Brad Turpin
DIAdem Product Support Engineer
(5,190 Views)
