DIAdem
Is there a way to make this type of Script run the data faster?
It is seems that when I am running this type of script on a lengthly data column it takes a long time to run.  Is there anyway to speed this up?
if Data.Root.ChannelGroups(1).Channels.Exists("Amber Warning Lamp Status") then
lst = globusedchn + 1
j = chnlength(1)
call chnalloc("AMBER_LAMP",j)
for i = 1 to j
State = cht(i,"[1]/Amber Warning Lamp Status")
IF dict3.Exists(State) THEN
chd(i,lst) = dict3.Item(State)
end if 'dict3
next
Call ChnPropSet(("[1]/AMBER_LAMP"), "unit_string", "Off/On") 'Set Unit
End if 'Parameter Name
(5,431 Views)
Hi Jcheese,
Please gibe this a try:
dim oCurrGroupChns, oAmberWLSChn, oAmberLampChn
set oCurrGroupChns = Data.Root.ChannelGroups(1).Channels
if oCurrGroupChns.Exists("Amber Warning Lamp Status") then
  set oAmberWLSChn = oCurrGroupChns("Amber Warning Lamp Status")
  set oAmberLampChn = oCurrGroupChns.Add("AMBER_LAMP")
  for i = 1 to oCurrGroupChns(1).Size
    State = oAmberWLSChn(i)
      oAmberLampChn(i) = dict3.Item(State)
    end if 'dict3
  next
  Call oAmberLampChn.Properties("unit_string").Value = "Off/On"
Greetings
Walter
(5,415 Views)
Sorry, This did not work.
Gave two error messages
Error in <NoName(1).VBS> (Line: 16, Column: 3):
Argument not optional: 'Add'
Error in <NoName(1).VBS> (Line: 25, Column: 54):
Expected end of statement
(5,407 Views)
I didn't test it because I have not test data for the problem
Please try this:
dim oCurrGroupChns, oAmberWLSChn, oAmberLampChn, i, state, dict3
set dict3 = CreateObject("Scripting.Dictionary")
  set oAmberLampChn = oCurrGroupChns.Add("AMBER_LAMP",DataTypeChnString)
    end if 'dict3
  next
 Greetings
Walter
(5,397 Views)
