DIAdem
How do I tell the CMD.exe to copy certain files from DIAdem?
I am a bit confused on how to tell CMD.Exe to copy certain files.
Goal, I want to copy
.VBS
.URI
.TDR
from V:\ drive >>> to D:\ drive
I do want to have to call 3 different CMD boxes to complete this but I will.  Is there any way to do it?
Call
ExtProgram("cmd.exe","/c xcopy V:\test\Technical_Information\DIAdem_Scripts\*.vbs D:\\Technical_Information\DIAdem_Scripts\ /y /d /c /i /s")
(5,590 Views)
Is it possible for you to use the DIAdem command FileCopy for this?
Greetings
Walter
(5,589 Views)
Would it work if you are pulling files from a Server ?
(5,584 Views)
The problem I have found with FileCopy cmd is that it copies everything but with the xcopy in CMD.exe I can use the /d switch to help with speed of download.
Can FileCopy do that ?
(5,576 Views)
Not with one command, but DIAdem supports several file handle commands like FileDateGet or FileAttrCheck (please have a look at the DIAdem help). With that you can check whether to copy a file or not.
Greetings
Walter
(5,568 Views)
