DIAdem
It's necessary to have a script modul license to run scripts?
We have a lot of Workstations, but only a few of them have a license for scripts.
Unfortunately it is not possible to buy the script modul separately.
There are any possibilities to run a script without the "script-maker-modul" ?
Greetz
(4,108 Views)
Start DIAdem with desktop parameters.
eg "C:\Programme\National Instruments\DIAdem 10.2\DIAdem.exe" /CScriptstart('c:\DatenSprint\start.vbs')"
(4,106 Views)
Hi foyar,
Your question could be interpreted in a number of ways.  I'm going to answer the question, "Do I need to have a version of DIAdem with a SCRIPT panel in it in order to run a DIAdem script?"-- the answer is NO.  DIAdem Base does not have the SCRIPT panel but will run all DIAdem scripts.  You do, however, need to have DIAdem installed in order to run a DIAdem script.
Brad Turpin
(4,101 Views)
Accepted by foyar
Thanks a lot!!!!!!
(4,032 Views)
