DIAdem
Kvaser time history file incorrectly converting time channel
I am using Kvaser Memorator for collecting data and when I use an older version of Kvaser Memorator Professional (2.0.6.600) to extract a .log file and then run through the CAN converter in Diadem 2011, the time channel comes in correctly.  If I use a newer version of Professional (3.02.186) to extract the same .log file and run through the CAN converter in Diadem 2011, the time channel is off by a factor of 10 (example a 30 second test now shows 3 seconds).  We have tried other permutations such as different files and even different versions of Diadem, but it still comes back to different versions of Kvaser Memorator Professional's writing of the .log file (or interpretation thereof by Diadem).  Attached is the .log file from the 3.02.186 version of Kvaser Memorator Professional.
Any help is appreciated.
(4,707 Views)
Hello Rapom,
Thank you for your information. It seems that the format in the new software from Kvaser has changed. We need to get in contact with the company to get the necessary information's, to be able to extend the converter in DIAdem.
Greetings
Walter
(4,696 Views)
Hello Rapom,
As we assumed has Kvaser changed the file format. That was done in 2011-05-03 for version 2.9.850. Now they have a file format which is different (only the timestamp with a factor 10) to Vektor LOG files. In consequence to those facts we are going to add a new separate buslog converter for Kvaser log files for the next DIAdem version. In the meantime you need to calculate the offset correction by your own.
Greetings
Walter
(4,670 Views)
