DIAdem
Linear Regression with limits
I have a data set that is plotted with X Axis = Load(kg) (range 100kg to 1500kg) and Y Axis = Wheel Z Height Displacement (mm) (range -75mm to +100mm).  Is there a way to limit a linear regression to the data range of -20mm to +20mm or 20% to 80% of the Y values on the Y axis?  Would it be best to create a data set that was only in the desired range and do the regression on the reduced data set?  If that is the case what would be a good way to copy the reduced data set to a new channel?
Wayne
(3,994 Views)
Hi Wayne,
As far as I know, the only way to limit the regression is to filter the data channel so that the undesired values are set to NoValues or deleted.  You could use a Calculator expression to do this quite easily-- let me know if you need assistance with that.  The result of the Calculator execution could be a new filtered channel or the same channel with edited values.
Brad Turpin
DIAdem Product Support Engineer
(3,980 Views)
I think I have an idea as to what to do.  I still need to retain the integrity of the original data, therefore I will be creating new channels.
In a script you could do a loop looking for a value that is within the range then copy that data set to the new channel.  Are there any builtin commands that would make this process quicker or more streamlined?  All I know to do is to look at each value with CHD and make the decision from there.
Wayne
(3,975 Views)
Hi Wayne,
For this use case I'm going to recommend the old FormulaCalc() function and syntax instead of the newer ChnCalculate():
R1 = -0.5 ' lower Y threshold
R2 = 1.5  ' upper Y threshold
L1 = CNo("[2]/Noise_3") ' raw data channel
Call FormulaCalc("Ch('Fit Data'):= Ch(L1) + NoValue*(Ch(L1)<R1) + NoValue*(Ch(L1)>R2)")
Ask if you have additional questions,
Brad Turpin
(3,960 Views)
