DIAdem
work with two or more files in one navigation window
Is it possible to work with more files in the navigator at the same time ? I have two files and i want load and save they without the other. Now i load file one and then file two, but the navigator put the groups and channels from the second file in the first one. And i have not the chance to save the files alone. (DIADEM 10.2)
Thank you very much, for your answers
(3,318 Views)
Hi Pohlan,
There is no way around this in DIAdem 10.2, and that likely won't change in the future.  The Data Portal holds all the channels that have been loaded into DIAdem application memory, and while the group structure from the original data files is preserved, the file hierarchy distinctions are not maintained.
What you can do is save selected channels/groups from the Data Portal.  So you can load, say, one group from file 1 and a second group from file 2, then you can save only group 1 to an external file A and then save only group 2 to an external file B.
Ask if you need more info on selective saving,
Brad Turpin
DIAdem Product Support Engineer
(3,306 Views)
