DIAdem
Loading C3D files into Diadem
Hi
Has anyone tried to load C3D files into Diadem version 10.0?
(4,144 Views)
Hi Dancer, can you please send some example files to DataPlugins@ni.com.
(4,130 Views)
Hello Stefan
Thanks for your reply.  I tried opening the link you indicated DataPlugins@ni.com but it does not seem to work.  Would you just verify the address.
(4,122 Views)
Dancer,
DataPlugins@ni.com is an email address. Could you please send some example files to this address so that we can look into it ?
Is the "c3d" format you refer to the one described on www.c3d.org ? If so, your files would be meant as a supplement to the example file available from that webpage
Andreas
(4,116 Views)
Hello Andreas
Perhaps "link" was the wrong word to use.  I could not get the DataPlugins@ni.com email address to open to MS outlook like an embedded address usually does.
Thanks for offering to look at the sample file I sent you to the above address.  it works if I copy/paste it in the address field
(4,107 Views)
