DIAdem
Map generated by the script and transfered into REPORT
I tried replacing the two lines as you suggested but it didn't help.
I got a map in the VIEW but it shows some generic location and the route is missing.
My version of DIAdem is DIAdem 20.0.0f7762 (64-bit), Packet 1 is Professionalk edition.
I didn't get any error message.
Here is the complete code for reference:
Dim oMySheet, oMyChart, oMyArea, oMyNewArea, oMyCurve
Call View.NewLayout()
Set oMySheet = View.ActiveSheet
oMySheet.Name = "RouteMap"
Set oMyArea = oMySheet.ActiveArea
oMyArea.Active = True
oMyArea.DisplayObjType = "Map"
Set Sheet = View.ActiveSheet
Set Area = Sheet.ActiveArea
Set Map = Area.DisplayObj
AreaName = Area.Name
Map.MapType = "Cache"
Map.ZoomLevel = 12
Map.ShowTrack = True
Map.MapMovingMode = "Pan"
Map.UseCache = True
Map.CachePath = "C:\Users\Public\Documents\National Instruments\DIAdem\MAP Cache\"
Map.SynchronisationChannelName = "[9]/TripTime"
Map.LongitudeChannelName = "[9]/GPS_Longitude"
Map.LatitudeChannelName = "[9]/GPS_Latitude"
Map.ColorChannelName = "[10]/imGPS_GROUND_SPEED"
Map.SynchronisationDimension = "X-Cursor"
Map.LongitudeDimension = "Y-Cursor"
Map.LatitudeDimension = "Z-Cursor"
Call ScriptStart(ProgramDrv & "Resource\VwLayTrans", "VWTransViewRep", False)
Set Sheet = Report.Sheets(Report.Sheets.Count)
Set Image = Sheet.Objects(AreaName)
Image.UseOriginalRatio = TRUE
Message 11 of 12
(789 Views)
An important step is to add the command:
View.ActiveSheet.Cursor.P1 = 1
This is required to get DIAdem to move onto the path so the map zooms to your data, otherwise it will remain on the outskirts of Aachen.
Attached an example python script.
Message 12 of 12
(615 Views)
