DIAdem
Maximum number of analog input channel
Hi all,
I have an NI USB-6229 and using DIAdem 10.2 to implement my measurements.  Basically the NI USB-6229 should be able to measure up tp 32 analog channels, but somehow from channel 26th DIAdem can not show any signal and I receive "NoValue".  Is there any limit for the number of analog input channels?  Has anyone face the same problem before?
Kiana
(5,375 Views)
Hello Kiana,
I am going to test this behaviour and give your additional information as soon as possible.
regards,
AmirG
(5,357 Views)
Hello Kiana,
Sorry for the delay but I was not able to find a USB 6229 to test it.
I agree with you, the NI USB 6229 should be able to acquire up to 32 RSE analog channels and there is not limit for the number of analog input.
I have tested this behaviour using NI USB 6218 board without any problems. See attachment. Could you please tell me which DAQmx driver are you using?
In my opinion, it could be helpful to test your application using DAQmx Driver 8.6.1
NI-DAQmx 8.6.1 - Windows 2000/Vista x64/Vista x86/XP
http://joule.ni.com/nidu/cds/view/p/id/950/lang/de
Please feel free to contact me if you have any questions about this issue.
AmirG
(5,323 Views)
Hi Amir,
The driver we are using is DAQmx Driver 8.6.
Greetins,
Kiana
(5,289 Views)
Hi Amir,
Greetins,
Kiana
(5,275 Views)
Hello Kiana,
please try to use hardware clock instead of software clock.
regards,
AmirG
(5,162 Views)
Hello Kiana,
Now, the NI USB 6229 is able to acquire up to 32 RSE analog channels and there is not limit for the number of analog input.
I have a service pack for the driver,one for Diadem German and one for Diadem English.
Please replace this file in AddInfo-folder.
Thanks and with kind regards,
AmirG
(4,966 Views)
