DIAdem
Menage channels in one group
Hallo,
I'm using the script below to manage or modify a channel according with the condition, but now I need change a large number of channels according with a condition of one channel.
dim
 for a = 1 to chnlength(1)
    if chd(a,1) > 20 then
       chd(a,2) = nv  now, I need modify a lot of channels, like chd(a,2) until chd(a,300)
    end if
  next
Thanks so much
Message 1 of 8
(3,100 Views)
A complete example of how to use a DIAdem Analysis Event Search to "filter" that data can be found on my website at this link: http://www.savvydiademsolutions.com/blog.php?topic=blog-filter-channel-data-by-events   Feel free to contact me if you have any further questions.
Message 2 of 8
(3,029 Views)
Accepted by topic author Abimael
dim a, b
        for b = 2 To 300
           chd(a,b) = nv  now, I need modify a lot of channels, like chd(a,2) until chd(a,300)
         next
    end if
  next
Message 3 of 8
(3,014 Views)
Thanks very much! Works very well.
Only one question more, how can I delete the lines selected according with the condition?
Message 4 of 8
(3,001 Views)
You can call DataBlDel(channnel, startRow, #valuesToDelete)
http://zone.ni.com/reference/en-XX/help/370858N-01/comoff/databldel/
Message 5 of 8
(2,982 Views)
The link below shows how to perform an Event Search, and then use a custom dialog (that you can download for free) that will allow you to post-process the Event Search results.  You can either set those values to NoValue, or delete those rows.
http://www.savvydiademsolutions.com/analysis.php?topic=postprocess-event-search-results
Message 6 of 8
(2,967 Views)
Hallo
Sorry for my poor knowledge to scripting..I'm trying to change a channel base on a range of values from the other channel, I've tried a lot of thing, but doesn't work. Could you give me a suggestion?
dim a, b
    if chd(a,1) > 20 then (like between  60 until 70),
        for b = 2 To 300
           chd(a,b) = nv
         next
    end if
  next
Thanks Advanced
Message 7 of 8
(2,898 Views)
Hallo,
I'm just got the good results with this script below
for = 1 to chnlength(2)
aux = chd(a,1)
if aux>cuti1 and aux<cutf1 then
for b = x To y
chd(a,b)= nv
chd(a,b)= chd(a,b)
next
end if
next
Thanks Advanced
Message 8 of 8
(2,885 Views)
