DIAdem
MenuItemInfoGet
Can someone tell me, why the following script brings up the menuitem "testmenu" multiple times?
(3,380 Views)
This behaviour is really strange. If you start the sequence from your editor, everything is working fine. For debigging I added a msgbox in a cetrain line of the script - and suddenly the error did not occure any more. That is why I am not sure what is causing the problem. Nevertheless, I found a workaround.
DIAdem cannot dekete the testmenu if the menu itself is calling the script. In such case, the menuItemInfoGet function will return an emty string for the menu title. I added the empty string comparison to the if THen structure. To prevent the program to dissappear in an endless loop you have to check the menus backwards (step -1 in the for-loop)
sTemp1 = "SCRIPT"
Call MenuItemCountGet(sTemp1,"M")
iTemp1 = menuitemcount'Deleting existing Menus
for iIndex
1 = iTemp1 to 1 step -1
call MenuItemInfoGet(sTemp1, iIndex1)
if (MenuItemTitle = "testmenu") or (Menuitemtitle="") then
call MenuItemDel(sTemp1, iIndex1)
end if
next
Call MenuItemadd(sTemp1,iTemp1 + 1,"MENUITEM","testmenu","scriptstart("""&autoactpath&"menutest3.vbs"")")
(3,380 Views)
