DIAdem
Merge two element list
Hi
I have create an Element List filtering some channels of a group
Dim mSyncLst, iGrp
Set iGrp = Data.Root.ActiveChannelGroup
Set mSyncLst = Data.GetChannels(iGrp.Name & "/ABC*") 'List With Several Channels
I would like to add to the mSyncLst the channels containing DEF. e.g. Data.GetChannels(iGrp.Name & "/DEF*"), which also contains several channels. Using the method Add mSyncLst, only allows to append one channel each time.
Thank you
(4,603 Views)
Hi dslemusp,
This is a good idea.  Would you please post this suggestion at www.ni.com/diademideas ?
Brad Turpin
DIAdem Product Support Engineer
(4,558 Views)
