DIAdem
Microsoft Script Debugger
Hello !
   I have DIAdem11.0 & Microsoft Visual C++ 2005 express edition. I want to debug the .vbs scripts, which is unfortunately not possible. Please let me know why this is so (the help says that if script debugger is there, then it should be possible to use the debug mode) and more importantly, how I can circumvent this situation.
  Es gibt ein paar diskussions über dieses Thema hier. Aber mein Deutsche ist leider nicht gut. Deshalb habe ich nur etwas verstanden. Ist eine Übersetzung auf Englisch möglich?
Mit freundlichen Grüßen / With warm regards,
Saurav Mukherjee
Message Edited by Mukherjee on 08-12-2008 09:00 AM
Message 1 of 11
(7,863 Views)
Hi Saurav Mukherjee,
The debugger that you have to download is the Microsoft VBScript debugger, not the Microsoft Visual C++ debugger.  The VBScript debugger is a very small installation that you can get from Microsoft for free.  Microsoft does not allow other products (i.e. DIAdem) to install their VBScript debugger.
Brad Turpin
Message 2 of 11
(7,842 Views)
Hello Saurav,
The debugger can be found here (well, at least until Microsoft decides to change the link again):
http://www.microsoft.com/downloads/details.aspx?FamilyID=2f465be0-94fd-4569-b3c4-dffdf19ccd99&DisplayLang=en#AdditionalInfo
The version of the debugger is 6,0,0,8424 if you check in the "DIAdem Help - About - Script Engine" menu.
Otmar D. Foehner
Message 3 of 11
(7,835 Views)
Dear Otmar & Brad,
       Thanks for your help. However I'm not able to find this script debugger in MS website. :mansad: Could you attach the same in your reply?
       Thanks in advance,
With warm regards,
Saurav
Message 4 of 11
(7,810 Views)
Hi Saurav,
I'm curious, are you unable to connect to the URL that Otmar posted, or are you unable to use that Microsoft web site to download the VBScript debugger?  I rather doubt that I'm authorized to post an installer from Microsoft in this forum that they have specifically protected behind an authentic Windows check at their web site.
Brad Turpin
Message 5 of 11
(7,807 Views)
Hi Brad,
    I went to the url. After the few authencity checks, MS redirects me to a page saying that the particular download is not available!
WIth warm regards,
Saurav
Message 6 of 11
(7,802 Views)
Hello Saurav!
The link should work. Wich OS are you using?
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
Message 7 of 11
(7,799 Views)
I'm using WinXP Professional version. The authenticity check is successfully done. After it a page opens with the information that the download I'm looking for is unfortunately not available!!
MfG,
Saurav
Message 8 of 11
(7,779 Views)
Hello Saurav!
You have the same OS. This is not the reason for the problem. Can you try to download on another machine?
Matthias
Matthias Alleweldt
Twigeater?
Message 9 of 11
(7,777 Views)
Accepted by Mukherjee
Saurav,
Please send me an email to: myfirstname DOT mylastname AT ni DOT com (no middle initials) and I'll send you an alternative way to get to this download.
Message Edited by Otmar on 08-15-2008 07:35 AM
Otmar D. Foehner
Message 10 of 11
(7,767 Views)
