DIAdem
Microsoft Word Template
I have a DIAdem-REPORT Layout (.TDR) and want to create a Microsoft Word Template. I just want to convert this TDR File into a Word File. Is this possible?
Thank You
Regards
(4,738 Views)
Hello Daniel,
There is an example in DIAdem that shows how to populate a Word Template from DIAdem, with the contents of the TDR (as a static image) and by adding some variables to the Word document as a small table.
Please have a look here in the help system:
You can look at the VBS code for the Script by selecting the Word_OLE.VBS code in the right part of the dialog.
I hope you can find some helpful information in this example,
     Otmar
Otmar D. Foehner
(4,734 Views)
Hello Otmar,
I already found this example, but I can´t understand the scipt. For one a WordTemplate "Wrd_OLE.dot" already exists and will be loaded by the script, but I don´t have a WordTemplate of my .TDR Template and I don´t find a way in this script how to do.
Is there another way?
Regards
(4,711 Views)
Hello Daniel,
I'd like to get a better understanding of what you are trying to achieve.
Are you actually trying to build a Word template from outside of Word? (I am not sure that's possible)
Would you simply like to embed the result of a DIAdem report (in form of a JPG, PNG, GIF or other image format) into an empty Word document?
What would you like the end result of your task to be? Running A Script in DIAdem that automatically transfers a single page into a Word document? Something else?
Please describe the task in a little more detail so we can steer you into the right direction to solve your issue.
Otmar D. Foehner
(4,690 Views)
Hello Otmar,
I already inspected the example that you posted, but I can´t apply this example to my template. I think there is already a template in Word format in this example and because of this I can´t use it.
Actually I created a template in DIAdem in .TDR format. This is just a template with empty charts. My desire is to convert this .TDR file which I just can open with DIAdem, in a format which I can open with Word. The only difference is the format of the file. The content of the templates should be the same, empty charts. I don´t use values, just the empty template.
Thank You
Regards
(4,681 Views)
