DIAdem
what is the method/algorithm used by Diadem for peak search?
Hi all,
Can you please let me know what method/algorithm is used by Diadem for peak search? Please note I am familier with peak search function in Diadem but I need to know the theory/algorithem that it uses to find the peaks.
Hossein
(6,321 Views)
Accepted by topic author hossein.askarinejad@gmail.com
Greetings Hossein
Check the last paragraph of this document.
Let us know if that answers your question or if you have further inquiries on this subject. Have a nice day!
Luis J.
(6,248 Views)
wHAT IS THE METHOD OF IMPLIMENTING THIS PEAK SEARCH INTO REPORT
(4,163 Views)
Hi Destiny,
The DIAdem Peak Search functions are all located in the ANALYSIS panel.  No matter which one you use, you will end up creating a resulting pair of channels called "PeakX" and "PeakY" (or similar).  You have to graph/display these resulting "PeakX" and "PeakY" channels in REPORT.
There is no peak search built into REPORT directly.
Brad Turpin
DIAdem Product Support Engineer
(4,140 Views)
