DIAdem
Moving average in DIAdem
Hi Erik,
If you're using the command DataFileLoad(), then you will get appended Groups.  If you use the command DataFileLoadSel(), then you will get appended Channels in the existing default Group.  If you call DataDelAll before loading, the Data Portal will empty and you will only get the newly loaded Groups/Channels.
Brad Turpin
DIAdem Product Support Engineer
Message 11 of 11
(922 Views)
