DIAdem
Multiple File Import Error
Accepted by topic author Denis.Vashuk
You can either load all search results
Navigator.LoadData(Navigator.Display.CurrDataFinder.ResultsList.ResultsElements)
or only the selected result elements
Navigator.LoadData(Navigator.Display.CurrDataFinder.ResultsList.Selection)
Hope that helps.
Message 11 of 16
(2,753 Views)
LoadData on the full element list still throws an error but you can load them individually inside a for loop.
Thanks, that should get me going.
Message 12 of 16
(2,747 Views)
Hi Denis,
When was the last time you updated your DEWESoft DataPlugin?  I seem to recall that loading multiple files was a bug in that DataPlugin that got fixed a little bit ago.
Brad Turpin
DIAdem Product Support Engineer
Message 13 of 16
(2,731 Views)
Hi Denis,
I spoke to quickly.  This issue was reported and investigated, and the problem is that the DEWESoft API can only open one file at a time.  Our DataPlugin uses that API and has no way around this limitation.
Keep using the workaround,
Brad Turpin
Message 14 of 16
(2,728 Views)
Does the DataPlugin work on newer *.dxd files from Dewesoft X daq sw?
Message 15 of 16
(2,024 Views)
Hi tuntugacho,
The download site for the DataPlugin says it works with *.dxd files, but that the DataPlugin was last updated on March 12, 2018.  If there are significant changes to the disk footprint encoding of *.dxd files that have happened since then, then it's possible the DataPlugin won't react properly to those files.
Could you post a few *.dxd files that give you trouble in DIAdem?  Or email them to me at brad.turpin@ni.com.
Brad Turpin
Principal Technical Support Engineer
NI
Message 16 of 16
(2,016 Views)
