DIAdem
Multiple Plots Cursor
I am trying to use Diadem for the first time. I am used to LabVIEW XY Graph and the possibility to view multiple plots at once and scan Y scale values with multiple plots cursors. How to do something like this in Diadem? How to display Y values of all plots for one particular X value (see Cursor 4 from the attachment)?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(4,434 Views)
Accepted by topic author bienieck
Hello Michal,
Load your data file(s) in the NAVIGATOR panel. The file(s) will appear in the DataPortal window on the left side of the screen.
Change to the VIEW panel. Drag the X/Y channels (pick X first, then one ore more Y-channels - unless the signals are wave forms, then no X-channel is required) into the VIEW window (see image 1)
Once the data is visible in the window, select the "Curve cursor" from the toolbar (item 1 in the image below) and then click on the right border of the window to drag out the legend (item 2).
Now You can use the cursor and scroll through the data and see the data values in the legend.
Let me know if you have any other questions, DIAdem VIEW has great data inspection features, and this is just a very simple part. Having multiple synchronized windows with zooming is the next step.
Otmar Foehner
Viviota Software
www.viviota.com
Otmar D. Foehner
(4,389 Views)
Hi Otmar,
Do you know if it is possible to transfer this cursors table into a report with all the data?
Michał Bieńkowski
CLA, CTA, CPI
(4,362 Views)
