DIAdem
No syntax error for too many variables in ValMax()
A word of caution ... If you try this :
         MsgBox ValMax (1,2,3,4)
You may be surprised that the answer is 2, and there are no syntax errors flagged by DiaDem 2010 SP1.
The code needs to read :
         MsgBox ValMax ( ValMax(1,2) , ValMax(3,4) ).
(3,574 Views)
Hello Colin,
The function works correctly according to the help system, but I agree that it should issue an error message when more than two parameters are entered. I have forwarded this to the DIAdem R&D team to create a fix for the next release of DIAdem that will display an error message when more than two parameters are entered for ValMax.
Thank you for the notice.
Command: ValMax
Determines the greater of two numbers.
ReturnValue = ValMax(Value, Value)
Input Parameters
Value Specifies a numerical value.
Return Parameters
ReturnValue The return value is a Real variable type.
Otmar D. Foehner
(3,565 Views)
Hi Colin,
I always use MinV() and MaxV() personally.  They complain if you try to use more than 2 parameters.
Brad Turpin
(3,562 Views)
