DIAdem
Object "Table1" unknown or not open" Problem
I have the Object "ExceedTable1" unknown or not open Problem.
The code should create several tables with values and display them in the report. Right now I only get the last table, and all the previous tables are not created and Object "ExceedTable1" unknown or not open Problem occurs.
The code is as follows:
For i = 1 to NumOfTables If Use_Table(i) = True Then
If i <> 1 then
Call GraphSheetNew("Status Page" & i)
Call GRAPHSHEETMOVE("Status Page" & i, "Front Spectrum Overall")
GraphSheetRefSet("Status Page" & i)
End If
Call GraphObjNew("2D-Table","ExceedTable" & i) 'Creates a new 2D axis system
Call GraphObjOpen("ExceedTable" & i) 'Opens the axis object
D2TabChnName(1) = Data.Root.ChannelGroups("Exceedance").Channels("Date" & i).Name
D2TabChnName(2) = Data.Root.ChannelGroups("Exceedance").Channels("Parameter" & i).Name
D2TabChnName(3) = Data.Root.ChannelGroups("Exceedance").Channels("Feature" & i).Name
D2TabChnName(4) = Data.Root.ChannelGroups("Exceedance").Channels("Magnitude" & i).Name
D2TabChnName(5) = Data.Root.ChannelGroups("Exceedance").Channels("Time" & i).Name
D2TabChnName(6) = Data.Root.ChannelGroups("Exceedance").Channels("Number" & i).Name
D2TabNumFormat(1) = "#hh:nn:ss#"
D2TabGrid(1) = True
D2TabGrid(2) = True
D2TabAutoScalTyp = "AutoMax"
D2TabTop = 10
D2TabBottom = 10
D2TabLeft = 10
D2TabRight = 10
Call GraphObjClose("ExceedTable" & i) 'Closes the axis object
End If
End If
The weird thing is that everything works fine when I use the debug mode. As soon as I exit it and try to just run the code, only the last table is created.
Thank you
Egor
(3,874 Views)
This issue was fixed by adding
Call Pause(5) between
Call GraphObjNew("2D-Table","ExceedTable" & i) and Call GraphObjOpen("ExceedTable" & i)
Brad,
Do you know why this problem happens?
Thank you
Egor
(3,858 Views)
Hi Egor,
No, I don't know why this is happening.  I edited your script to run on my computer, and it worked fine with no errors in regular run mode.
  If 1 = 1 THEN 'Use_Table(i) = True Then
    If i <> 1 then
      'Call GRAPHSHEETMOVE("Status Page" & i, "Front Spectrum Overall")
    End If
    D2TabChnName(1) = "1" ' Data.Root.ChannelGroups("Exceedance").Channels("Date" & i).Name
    D2TabChnName(2) = "2" ' Data.Root.ChannelGroups("Exceedance").Channels("Parameter" & i).Name
    D2TabChnName(3) = "3" ' Data.Root.ChannelGroups("Exceedance").Channels("Feature" & i).Name
    D2TabChnName(4) = "4" ' Data.Root.ChannelGroups("Exceedance").Channels("Magnitude" & i).Name
    D2TabChnName(5) = "5" ' Data.Root.ChannelGroups("Exceedance").Channels("Time" & i).Name
    D2TabChnName(6) = "6" ' Data.Root.ChannelGroups("Exceedance").Channels("Number" & i).Name
    D2TabGrid(1) = True
    D2TabGrid(2) = True
    D2TabTop = 10
    D2TabBottom = 10
    D2TabLeft = 10
    D2TabRight = 10
  End If
Brad Turpin
DIAdem Product Support Engineer
(3,855 Views)
