DIAdem
how can i uninstal the DIAdem 11 evaluationsoftware
Message Edited by Sebastian83 on 06-29-2009 04:18 AM
(3,458 Views)
Hello Sebastian,
Please open your START menu, go to SETTINGS and chose the CONTROL PANEL.
From the CONTROL PANEL WINDOW, select "Add or Remove Programs" - scroll to "National Instruments Software" and press the "Change/Remove" button. Select the software you wish to remove from the dialog and press the REMOVE button.
That should remove the product(s) you wish to get rid off ...
 Otmar
Otmar D. Foehner
(3,449 Views)
