DIAdem
OdsValAlloc command
Can you help me understand why the following code does not work.
Call OdsValAlloc("Elvis","ODS_TYPE_STRING")
Elvis = "Graceland"
MsgBox Elvis_
Call OdsValFree("Elvis")
I get the error below....
Error in (Row: 1, Column: 2):
Type mismatch: 'OdsValAlloc'
DIAdem version is 8.00.981
(4,468 Views)
Hi Sarm,
First start with a newly launched DIAdem, then execute your above code with the following changes. Note the 3rd parameter in the first line and the missing underscore_ in the third line.
Call OdsValAlloc("Elvis", "ODS_TYPE_STRING", 0)
Elvis = "Graceland"
MsgBox Elvis
Let me know if this still gives you trouble,
Brad
(4,468 Views)
I made the 2 changes and got the same error.
(4,468 Views)
I tried the code Brad posted with version 8.1.1534 and it is working correctly.
Do you have access to version 8.1 to test this?
Otmar
Otmar D. Foehner
(4,468 Views)
No, unfortunately I do not have access to version 8.1.
(4,468 Views)
You can download a demo copy of version 8.1 from www.ni.com/diadem.
It will run for 30 days and allow you to verify that things are woking on your computer.
Otmar
Otmar D. Foehner
(4,468 Views)
