DIAdem
Online Alarm logfile
at first there is to say, that I work with DIAdem 10.2.
I want to create a program for longtime monitoring of signals. When one signal gets beyond a limit there should be an alarm.
I try to do this with a displayed online alarm file (in package handling routine). My dac-file is a modification of dac-example:"Alarm8.dac".
So now to my problem: Is there a way to save the online displayed file on my computer (with or without a script)? Because when I stop the dac-file the alarms are deleted.
Please help me in this case
(4,483 Views)
Accepted by topic author Fabulous W
Hi There,
in the Palette "Alarmsystem" there is a log function where you can direclty  wire the output of alarmtext to it and it will log your Alarms to a txt-file.
I hope this helps,
RMathews
Ramona Lombardo
Applications Engineer, NI Germany
Certified LabVIEW Developer
(4,474 Views)
