DIAdem
ISF plugin
I am trying to import to DIADEM an ".isf" file from a measurement with a Tektronix oscilloscope.
Although I have the necessary data plugin and I have imported
in the past such files from other Tektronix oscilloscopes, this time I get an error message:
"The plugin supports only Int16 Data"
I attach the file I am trying to import. Thanks in advance for your help!
Yannis
(5,564 Views)
Hello Yannis,
The dataplugin team will take care of the problem.
Could you please send us more test data (DataPlugins@ni.com).
Thanks in advance
Heike
(5,556 Views)
Hello Yannis,
We modified the existing plugin so that your problem should be solved.
You can find the new plugin here:
http://zone.ni.com/devzone/cda/epd/p/id/2985
Best regards
Heike
(5,538 Views)
