DIAdem
carriage returns causes enclosed VBScript to run and fail to complete
I am finding a weird problem.
I have my autosequence file working perfectly without any errors but the same VBscript file when enclosed runs and fails to complete I am unable to figure what is wrong.
I am using �vbCRLF� to read/write from INI files into the script files. Other than this I dont use any cariage returns. When Iopen my Script files in other editors like Notepad etc, I am able to find a small square kind of a character. Is there some unseen Carriage Returns (CRs) or Line Feeds (LFs) or some combination due to which I am facing this.
(I am using DIAdem 9)
Can anyone please help me out with this immediately.
Thanks in advance,
Wating for your quick response.
(4,400 Views)
please send me an small example for this behaviour.
My email address: walter.rick@ni.com
Greetings
Walter Rick
(4,400 Views)
We found another possible reason for the behavior you described. If you are using the operating system NT4, Win200 or Win-XP DIAdem stores the VBScript files in Unicode format. You can change that in DIAdem-SCRIP->Settings->Desktop parameters->Panel specific.
I hope this will solve the problem
Greetings
Walter Rick
(4,400 Views)
Hello, I'm searching through the Diadem Forum and I didn't find something that I could use.
I have to exchange text information between to programs (DIAdem and CatmanProfessional).
My initial idea is to create INI file to acomplish this. Catman has a function to read or write quite easily describing the SECTIONS and KEYS of this INI file.
However I can't see something on Diadem Script. It onlys read or write Text files... And then I must extract the key values cutting and finding one by one.
I saw that Labview has an open VI to treat this, is there nothing similar for DIAdem?
(3,605 Views)
