DIAdem
PDF report export crashes DIAdem
Hello All,
After tring this and that, including deleting printers and restarting the computer, I am at my wits' end.
When I try to export a report procedurally using this code
Call PicPDFExport(DataReadPath & Data.Root.Name & ".pdf")
 I get the following error:
Bei der Ausführung des Befehls "PicPDFExport" ist ein Laufzeitfehler aufgetreten.
Fehlerart : UNKNOWN
Fehleradresse : 00048036
Modulname :DIAdem.exe
Has anyone had something like this happen?
The report is a two-page layout, both landscape, with the first page containing a graph with 3 y axes (one on the left, two on the right), and the second page containing a graph with 2 Systems in one 2DAxis object.
Thank you in advance for any help and have anice weekend!
Leo Zschokke
Test Engineer C-EPS
ThyssenKrupp Presta AG
(6,036 Views)
Hello Leo,
Could you please give us the following additional information:
  1. DIAdem version
  2. Operating System
  3. PC specs (processor, RAM, free HDD Space)
These might help us narrow down the cause of the error.
     Otmar
Otmar D. Foehner
(6,024 Views)
Hi Otmar,
Certainly.
The version of DIAdem I am using is 11.3.0f4563 on Windows 7 64-bit with 90GB of free HD memory, which accounts for about two thirds of my total HD space.
Thank you for your help,
Leo
Leo Zschokke
Test Engineer C-EPS
(6,002 Views)
More information. After tweaking the script a bit and using the following code:
PrinterName = "winspool,Adobe PDF,LPT1:"
PDFFilename = DataReadPath & Data.Root.Name & ".pdf"
PrintRangeType = "AllPages"
Call PrintMaxScale()
Call PicPrint("WinPrint")
 I found out that the error must occur while the first page is being sent to the printer. I hope this helps.
Thank you,
Leo
Leo Zschokke
Test Engineer C-EPS
(5,990 Views)
Hi Leo,
I am not sure if it apllies for you as well, but this helped me to get PDFexport running for DIAdem 2012 on Win7 64bit:
http://forums.ni.com/t5/DIAdem/PDF-Export-Hangs/td-p/1697088
I used the Windows Vista instruction.
Phex
(5,887 Views)
