DIAdem
Page through a large query (Element Search)
We have about 4 million recordings in our database. DiAdem 2017 offers a limit
of 32000 elements in Element Search and 2.5 million in Column Search (for one column). Most of
our search queries on the database will have results in excess of 32000 and
sometimes we also need to export these results to a text file using a script (which is not possible with
Column Search).
Is there any way to access all results all at the same time or access all results a bunch at a time? (with / without code)
Thanks!
(2,300 Views)
Why is the export not possible using the column search.
Just load the properties into DIAdem channels and loop over the lines in the channels.
Option Explicit
dim oMyDataFinder : Set oMyDataFinder = Navigator.ConnectDataFinder("My DataFinder")
Dim oMyQuery : Set oMyQuery = oMyDataFinder.CreateQuery(eAdvancedQuery)
oMyQuery.ReturnType = eSearchFile
dim oMyConditions : Set oMyConditions = oMyQuery.Conditions
Call oMyConditions.Add(eSearchFile,"dataPluginName","=","TDMS")
oMyConditions.Logic = "C1"
Dim oMyResultsColumns : Set oMyResultsColumns = oMyDataFinder.CreateResultsColumns()
call oMyResultsColumns.RemoveAll
call oMyResultsColumns.Add(eSearchFile, "folder")
call oMyResultsColumns.Add(eSearchFile, "fileName")
call oMyResultsColumns.Add(eSearchFile, "indexStatus")
call oMyResultsColumns.Add(eSearchFile, "dataPluginName")
Call oMyDataFinder.SearchProperties(oMyQuery, oMyResultsColumns, 2000000)
Dim oMyImportParameter : Set oMyImportParameter = Navigator.Settings.CreateImportParameter("Load")
oMyImportParameter.LoadReturnMode = eLoadReturnChannelElements
data.root.clear
data.Root.ChannelGroups.Add("target").Activate
dim channels : set channels = Navigator.LoadProperty(oMyDataFinder.ResultsProperties, ,oMyImportParameter)
dim nrOfresults : nrOfresults = channels(1).size
dim i : for i = 1 to nrOfresults
  logfilewrite channels(1).values(i) & channels(2).values(i) & " " & channels(4).values(i)
(2,275 Views)
Thank You Andreas!
This works. I was able to export results with your sample code.Smiley Happy
(2,257 Views)
