DIAdem
Passing arguments to script
I created a dialog which load folder files and when i click the button i run another script by StartScript(...) command
How could i pass my arguments to the script (the files paths)?
Message 1 of 12
(8,435 Views)
Hi OzShimon
All variables that a declared in the "Declaration part" are also available in subscripts. The "Declaration part" is the very top script part outside of any procedure. These variables are global variables.
They have to  defined with dim, but can be changed everywhere. Of course you can call subfunctions with parameters like "Call MySub(ParamOne, ParamTwo)"
Hope this helps
Winfried
Message 2 of 12
(8,424 Views)
Hi Winfried,
That not what i meant.
For example:
 **My dialog contains one button and event click
the dialog code:
Dim obj
Sub Button1_EventClick(ByRef This)
     obj= "Hello World"
     Call ScriptStart("C:\Users\Oz\Desktop\test.vbs")
End Sub
**the script code(test.vbs):
Call MsgBox(obj)
I want to pass the- obj parameter to the test.vbs script .
How i do it?
Message 3 of 12
(8,419 Views)
Hi OzShimon
Why do you use ScriptStart. You can use Scriptinclude instead. Then you can use parameters as well. Please look at
http://zone.ni.com/reference/en-XX/help/370858K-01/comoff/scriptinclude/
for the differences.
Winfried
Message 4 of 12
(8,413 Views)
Accepted by OzShimon
Hey OzShimon,
As long as you use a Diadem predefined global variables (T1,T2,....)  you would be fine. You can also define user variables (.VAS files) or even declare your  own global variables with : Call GlobalDim("Myname").
These variables will not be re-initialized until you restart the script engine. So just changing "obj" for T1 your test should work
'Dim obj
     T1= "Hello World"
End Sub
Call MsgBox(T1)
Javier
Message 5 of 12
(8,409 Views)
Sorry for this second post but i missed to say that I totally agree with winner, using scripInclude seems to be the best option to pass parameters between script. However i giev you some info about the global variables cause migth be interesting if you want to pass info between dialog box...
Javier
Message 6 of 12
(8,399 Views)
Thanks to all of you,
I decided to use:  Call GlobalDim(....) because i need to passing parameters from dialog to script, but all the others options working .
Message 7 of 12
(8,395 Views)
i succeeded to declare user variables with Call GlobalDim("myVar") but how could i declare an array of strings with GlobalReDim ?
It's give me an error.
I tried: *Call GlobalReDim("myArray(2)")
Message 8 of 12
(8,344 Views)
Message 9 of 12
(8,344 Views)
Try it out;
f Not ItemInfoGet("MyArray") Then Call GlobalDim("MyArray")
GlobalReDim "MyArray(20,20)"
Javier
Message 10 of 12
(8,331 Views)
