DIAdem
Passing variable to Find function
I'm trying to find the first index where my accelerometer goes below -1G. I'm trying to use the Find function to do this, and having some syntax errors.
My code looks like this:
index = Find("Ch(""accelChannel"")<-1")
accelChannel is a variable that contains the name string of my data channel. I'm writing this script with the assumption that I won't know the name or index of the channel in my data structure. I have a dialog box that the user selects the channel and sets the accelChannel variable.
I'm trying to pass this string to the Find function to do the search, and I can't get it to work. Is it possible to pass a variable to the Find function?
(3,158 Views)
Accepted by sirwin
You can just create a string by resolving the value.
index = Find("Ch(""" & accelChannel & """)<-1")
(3,131 Views)
That worked, Thanks!
(3,125 Views)
Hi sirwin,
I find putting the channel name with """ quotes into the formula makes it hard for me to debug when the formula gets a little more complicated.  The following approach will work in all DIAdem versions:
T1 = "accelChannel"
index = Find("Ch(T1)<-1")
And this nicer, object-oriented approach will work in recent DIAdem versions:
Set DataChannel = Data.GetChannel("accelChannel")
Channels = Array(DataChannel)
Symbols = Array("Accel")
index = ChnFind("Accel<-1", 1, Symbols, Channels)
It's much better for debugging if the "accelChannel" channel reference fails outside the Find function.
Brad Turpin
(3,019 Views)
