06-17-2019 10:06 AM
Hello community,
i have the Problem with automation of the ChnRainCalc function. With the following code i wan't to analyze some functions.
Set analyseGroup = calcRoot.ChannelGroups.Add("Rainflow_analyse_Group")'Create new group
For i = 1 to Data.Root.ChannelGroups(4).Channels.Count
Call Data.Root.ChannelGroups(4).Activate()
RainInclFirstLastVal = False
ClassNo = 100
ClassBegin = Data.Root.ChannelGroups(4).Channels(i).Properties("minimum").Value
ClassEnd = Data.Root.ChannelGroups(4).Channels(i).Properties("maximum").Value
ClassWidth = (ClassEnd - ClassBegin)/ClassNo
ClassRangeWidth = (ClassNo * ClassWidth)
RainChnContain = "No. of classes"
RainMatTrans(1) = False
RainMatTrans(2) = False
RainOneParaCalc(1) = False
RainOneParaCalc(2) = False
RainOneParaCalc(3) = False
RainOneParaCalc(4) = False
RainSpecOnePara(1) = False
RainSpecOnePara(2) = False
RainSpecOnePara(3) = False
RainSpecOnePara(4) = False
Call ChnRainCalc("[4]/["&str(i)&"]","Automatic",1,0,"Cumulative")
I get the error message
Fehler: Es wurde keine Berechnung durchgeführt.
Does anyone know this error report and what is the real error behind the message?
06-17-2019 12:37 PM
Try
ClassBegin = Data.Root.ChannelGroups(4).Channels(i).Maximum ClassEnd = Data.Root.ChannelGroups(4).Channels(i).Minimum
06-17-2019 02:05 PM - edited 06-17-2019 02:08 PM
The Errormessage is still the same.
Additional i use the teachin function. The recorded script have the same error message.
07-09-2019 03:38 AM
I changed a bit your script. If this doesn't work, I need the dataset and the DIAdem version you are using.
dim oCalcRoot, oAnalyseGroup, oSourceGroup, oSourceGroupChns
set oCalcRoot = Data.Root
Set oAnalyseGroup = oCalcRoot.ChannelGroups.Add("Rainflow_analyse_Group") 'Create new group
Set oSourceGroup = oCalcRoot.ChannelGroups(4)
set oSourceGroupChns = oSourceGroup.Channels
Call oSourceGroup.Activate()
For i = 1 to oSourceGroupChns.Channels.Count
ClassNo = 100
ClassBegin = oSourceGroupChns(i).Minimum.Value
ClassEnd = oSourceGroupChns(i).Maximum.Value
Call ChnRainCalc(oSourceGroupChns(i), "Automatic", 1, 0, "Cumulative")
Greetings
Walter
