DIAdem
Problem with displaying mixed datatype in DIAdem
I have a problem with displaying the data came from csv file.
My system produces the data in the form like below:
Timestamp,BlockID,AlertID,Block Name,Block State,Description,Trigger
556,0x4056,0x95,BlkSrvL2Alerts,OK,MOTOR_CURRENT_SENSOR1_FAULT,Unknown
560,0x4056,0x94,BlkSrvL2Alerts,STOP_UNDF,MOTOR_CURRENT_SENSOR2_FAULT,Unknown
etc.
So: denary number, hex number, hex number, string, string, string, string
So far only one parameter which is displaying is denary number, the legend of  the rest parameters is gray-out on the chart.
Is it possible to display the data from my csv files? How to do this?
(1,691 Views)
Hi MimiKLM,
I can't find a way to does this directly, I think the way around this would be to use the script to read the the channels and convert to a different format.  The steps i would do are:
  • Import the CSV into the data portal
  • in the Script view, import a hex channel from the data portal,
  • convert all the hex data to decimal
  • create a new channel and add the converted channel to it.
  • Then you can use that converted data on a chart.
There maybe be a plugin that does that already, but I havent looked.  For the strings, I don't know. What information do you have in the strings?
For creating the script, these links should help:
(1,632 Views)
Fault statuses & fault sources
(1,630 Views)
Hi All,
If this file with the status values and the hex codes is actually a CAN log file, then you should use the Bus Log Converter in DIAdem to turn it into a TDM/TDX file of scaled and datetime-stamped channels, with each group containing all the data from one message.
Brad Turpin
Principal Technical Support Engineer
(1,595 Views)
