DIAdem
Report curve parameters - all groups
I used to be able to drag and drop a pair of channels from the portal to a Report axis system and the curve would appear on the graph. Now I get multiple curves because the curve definition automatically puts an asterisk in for the group name so that the pairs of channels with the same name in ALL the groups of the file will appear on the graph. How do I prevent this maddening behaviour without manually replacing the asterisk with a group number each time? All I want is the for the curve definition to relate only to the pair of channels that I drag onto the graph.
Thanks, Simon.
(1,899 Views)
Accepted by topic author Simon_Aldworth
Hi Simon,
I assume that your layout is running in the "Curve Expansion" mode. This parameter is part of the "Layout Parameters" and stored with the layout. If you uncheck the mode, D&D will work as expected.
Greetings
Walter
(1,850 Views)
