DIAdem
Showing results forย
Search instead forย
Did you mean:ย
Problem with "properties.exists" for CreateDataFileHeaderAccess in DIAdem 2014?
I have the following script:
Dim oMyDataFileHeaderAccess, oMyDataStore
Set oMyDataFileHeaderAccess = CreateDataFileHeaderAccess
dim mypath : mypath = "C:\MyFile.tdms"
Set oMyDataStore = oMyDataFileHeaderAccess.Open(mypath ,"TDMS", True)
logfilewrite oMyDataStore.RootElements(1).Properties.Exists("MyProperty") ' returns FALSE
logfilewrite oMyDataStore.RootElements(1).Properties("MyProperty").value ' returns the expected value
The "Properties.Exists" feature doesn't return what I expect.  If I have a file where the root property "MyProperty" exists (and I can access the value!), the Properties.Exists("MyProperty") returns false ๐Ÿ˜ž
Am I doing something wrong?  Thank you!
(3,150 Views)
Accepted by topic author JuliaDawkins
Hey Julia,
You have to set this property first before reading custom root properties ๐Ÿ˜‰
oMyDataStore.RootElements(1).Properties.ListInstanceProperties = true
Same for group and channel properties
Regards
Christian
CLA, CTA, CLED
(3,108 Views)
Perfect, thank you!
(3,091 Views)
