DIAdem
repport
Hello, i'm a beginner in the use of Diadem, indeed, in the basic repport that i use to visualize the results, in the master layout i want to decrease the size of the text, so i want a script that allows to decrease automatically the size of the text when the number of characters exceeds a certain number ( 18 for exemples). is that possible? thank you
(3,482 Views)
Hi Say,
This is how you would do that in a script for a regular REPORT textbox object, but i don't see a way to do the same thing for a textbox object from the Master Layout.  Perhaps Walter Rick knows a secret here.
Set Sheet = Report.Sheets(1)
Set TextBox = Sheet.Objects("Text1")
IF Len(TextBox.Text) > 18 THEN
  TextBox.Font.Size = TextBox.Font.Size - 2
  Call Report.Refresh
END IF
Brad Turpin
DIAdem Product Support Engineer
(3,456 Views)
Hello Brad
thank you , however, i wrote that script but it doesn't work and i don't know why, do you have any idea about what i must change ?
(3,450 Views)
Hi say,
I think you can only use static objects in your master layout.  I have not found a way to programmatically access REPORT objects from the master layout.
Brad Turpin
(3,418 Views)
